Machine tool suds pumps designed for the pumping of cooling liquids, cutting compounds and cutting oil. Flanged designed for vertical assembly directly on top of the coolant vessels. Minimum and maximum temperatures are 0-60'c. Not for pumping abrasives, so the liquid being pumped has to be filtered to stop impurities entering the pump chamber.
Voltage - 415
Stem - 270mm
Lpm - 24
Hm - 4
Watt - 90
M - 230
Kg 4
#Bazz #blauwe_pomp #blue_pump #NT270 #pomp #pump #Speroni #suds #suds_pump #vertical_sud_pump #verticale #water #water_pomp
