04 Two Piece Smoke Baffle System - SB-200
Blumcraft
The two-piece smoke baffle system isolates tempered or laminated glass panels against the shock of building movement. The SB-200 assembly permits easy glass panel replacement as the two sections are bolted together. The bolts are hidden by attractively finished filler strips. For safety, the glass panels are securely bonded and mechanically attached to the removable portion at Blumcraft’s factory. Smoke baffle systems are built in strict accordance with shop drawings prepared by Blumcraft’s engineering department. #07_87_00 #smoke_baffle #smoke_barrier #smoke_containment #Smoke_Containment_Barriers
